Simple Tube Question?
The cathode of the 1V is connected to pin 3. The plate (yes, the "top bar" is indeed the plate) connects to pin 2.
I prefer the NJ7P database, specs of the 1V (with drawings) are shown here:
http://www.nj7p.info/Common/Tube/SQL/Tub...hp?Type=1V
Simple Tube Question? - by Pepperoni - 01-11-2013, 03:30 PM
RE: Simple Tube Question? - by Ron Ramirez - 01-11-2013, 04:57 PM
RE: Simple Tube Question? - by Pepperoni - 01-12-2013, 04:25 PM
There are currently 7106 online users. [Complete List]
» 1 Member(s) | 7105 Guest(s)
