Bakelite block 3903AH info.
I didn't say to use 0.09. That's what the block originally came with. I mentioned that the closest vaule nowadays is 0.1uF in parentheses. Use that value and you'll be fine.
Bakelite block 3903AH info. - by Guest - 09-06-2007, 07:54 PM
[No subject] - by Chuck Schwark - 09-06-2007, 07:59 PM
[No subject] - by Guest - 09-06-2007, 08:13 PM
[No subject] - by Chuck Schwark - 09-07-2007, 04:02 PM
[No subject] - by Guest - 09-07-2007, 04:21 PM
[No subject] - by Carl Travis - 09-07-2007, 05:12 PM
[No subject] - by Chuck Schwark - 09-07-2007, 06:55 PM
[No subject] - by Guest - 09-07-2007, 07:38 PM
