Philco Model 41-296 Problems
    Thanks for the reply Arran, I am going to try to post the schematic for you to peek at.
Posts 6-7 are underlined in red, and on the antenna trans have continuity between them, so I figure the coil #8 is built in. (purple circle) Post 5 is underlined in blue/green.
I just don't see why anyone would link #7 to #5, even with a gimmic cap (edit; external antenna maybe?) -I also do not see where anything else comes off either of those two posts but lines to ground and/or the band selector switch -which are all replaced and accounted for.
Am I just seeing the work of some guy's half baked idea of fixing this thing 50 years ago here,(edit; or some wierd add on of some kind?) or am I completely missing something/being a noob? It's just that the wire was exactly like all the rest (although a bit gummy where twisted together) and the soldering was so perfect... just like every other blob of solder, except for the ones on a Sprague .003 cap that had obviously been replaced at one time and had a 'blob on a blob' if you follow.
Am I just going crazy over nothing on this part of my question?
RE: Philco Model 41-296 Problems - by Ron Ramirez - 01-09-2013, 07:33 PM
RE: Philco Model 41-296 Problems - by TheFightingHellfish - 01-12-2013, 12:45 AM
RE: Philco Model 41-296 Problems - by BrendaAnnD - 05-04-2013, 08:41 PM
RE: Philco Model 41-296 Problems - by Mondial - 05-04-2013, 09:25 PM
RE: Philco Model 41-296 Problems - by Raleigh - 05-05-2013, 01:49 AM
RE: Philco Model 41-296 Problems - by Raleigh - 05-06-2013, 12:32 AM
RE: Philco Model 41-296 Problems - by BrendaAnnD - 05-06-2013, 02:34 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
