Model 60 Antenna coil repair
Thank you Ron. I will try to get this done this weekend. The radio is playing well after the antenna so hopefully this will restore normal operation.
Model 60 Antenna coil repair - by SteveJB - 01-06-2013, 10:20 PM
RE: Model 60 Antenna coil repair - by kporter - 01-07-2013, 12:16 AM
RE: Model 60 Antenna coil repair - by SteveJB - 01-09-2013, 08:46 PM
RE: Model 60 Antenna coil repair - by Ron Ramirez - 01-09-2013, 10:04 PM
RE: Model 60 Antenna coil repair - by SteveJB - 01-09-2013, 10:44 PM
RE: Model 60 Antenna coil repair - by Ron Ramirez - 01-10-2013, 06:47 PM
RE: Model 60 Antenna coil repair - by SteveJB - 01-12-2013, 07:05 PM
RE: Model 60 Antenna coil repair - by SteveJB - 01-13-2013, 12:57 PM
RE: Model 60 Antenna coil repair - by Ron Ramirez - 01-13-2013, 02:20 PM
RE: Model 60 Antenna coil repair - by SteveJB - 01-13-2013, 02:38 PM
RE: Model 60 Antenna coil repair - by SteveJB - 01-13-2013, 07:12 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
