Federal Telephone and Radio Corp. E1025TB - Glass Dial Scale
Just the other brown Bakelite radio (seen in radiomuseun) I buy without glass dial.
RE: Federal Telephone and Radio Corp. E1025TB - Glass Dial Scale - by henrypal - 01-14-2013, 10:30 AM
There are currently 9433 online users. [Complete List]
» 1 Member(s) | 9432 Guest(s)
