Let's see your radio workbench!
I went high tech with mine.
I use a card table with a soldering iron sitting in one corner.
Clamp on light in the other corner.
Toolbox sitting on the floor underneath.
Radios lined up on all 4 walls.
How's that for a man cave.
murf
Let's see your radio workbench! - by Conelrad - 01-14-2013, 02:39 PM
RE: Let's see your radio workbench! - by murf - 01-14-2013, 04:00 PM
RE: Let's see your radio workbench! - by y2kbruce - 01-14-2013, 07:18 PM
RE: Let's see your radio workbench! - by shawn - 01-15-2013, 06:31 PM
RE: Let's see your radio workbench! - by y2kbruce - 01-16-2013, 08:22 PM
RE: Let's see your radio workbench! - by Arran - 01-16-2013, 08:59 PM
RE: Let's see your radio workbench! - by Dave - 01-17-2013, 06:34 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
