Candohm replacement
Thanks BrendaAnnD.
a) 35Z3 cathode is -1vDC
b) 35Z3 plate is 108vAC (line is 110vAC through isolation xfmr)
c) both in and out of field coil are -1vDC
d) B- common is same wire as original wire (but heat shrink covered to replace old rubber) and has continuity to other B- points
e) dial lamp is working (now that candohm was replaced with some power resistors http://philcoradio.com/phorum/showthread.php?tid=5697 )
Regards,
bob
Candohm replacement - by klondike98 - 01-05-2013, 04:33 PM
RE: Candohm replacement - by codefox1 - 01-05-2013, 05:04 PM
RE: Candohm replacement - by morzh - 01-05-2013, 06:10 PM
RE: Candohm replacement - by klondike98 - 01-05-2013, 06:39 PM
RE: Candohm replacement - by Arran - 01-05-2013, 10:35 PM
RE: Candohm replacement - by Phlogiston - 01-05-2013, 11:26 PM
RE: Candohm replacement - by klondike98 - 01-06-2013, 02:57 PM
RE: Electrolytic cap polarity question/advice - by klondike98 - 01-17-2013, 12:50 PM
Philco 89 indicator light.
46-1201 Trip Switch Spring
