38-7 bad pwr transformer?
Well, this is a bit embarrasing, but I was measuring ACV not DCV like I should have been. So voltages check good, and the problem hasnt repeated with hours of use. I'm thinking there was some kind of short at the field coil or output transformer. I did nothing more than let it cool completely, and fiddle with some wires around the field coil. Well it works again, so I won't try to fix it. Also finally found the short that was causing my 89L to stay silent since I bought it. I'm listening to it now for the first time. All in all a pretty good day!
Mike
38-7 bad pwr transformer? - by Guest - 09-21-2007, 09:13 PM
[No subject] - by rickd - 09-22-2007, 06:26 PM
[No subject] - by Guest - 09-22-2007, 07:49 PM
If the small signal ones, take any Ge transistor with unity gain good enough and Vce max 30 or so V. For the output....y...morzh — 03:43 PM
Yes, Michael. This winter I repaired this Westinghouse, RCA 121 and Zenit 5S29. All that remains is to veneer the Zenit ...RadioSvit — 03:28 PM
Thank you. I have one board completely de-populated. Just looking for the correct values. I'll let you know. Still h...R3Sons — 03:13 PM
Is this the one from the Fall Kutztown 2023?morzh — 02:59 PM
Philco 91 Restore Code ??
If it does not get narrower with strong signal and your AVC is OK, it could veru well be that the shadowgraph's magnet i...morzh — 02:58 PM
The width does not get narrower with generator. I think I will try some other cap values.dconant — 02:56 PM
410pF is a large capacitance to parallel to a compensator. As for the shadowmeter....yes, 3/8" is a bit wide, bu...morzh — 02:49 PM
My new nostalgic video... My weekly video on radio history Who is interested - come, watch, critically evaluate the qu...RadioSvit — 01:47 PM
The shadow meter in the radio is responding to tuned signals but it never goes to a very small shadow even on strong sig...dconant — 01:01 PM
91H Code 126 Restore
Hi Nick, I am finishing up a 91 code 121 (one speaker). The dashed line is for the code 221 (2 speaker) set. I see there...dconant — 11:17 AM
There are currently 4034 online users. [Complete List]
» 1 Member(s) | 4033 Guest(s)
