Stewart Warner R1495A
With respect to your SW 1495, that is an excellent set!!
If I remember correctly, the SW 1495 has a couple of 600V caps you should be aware of. Also, the initial V on the filter electrolytics was over 500. I believe that this was because I ran it on 120V without any step down, so you might want to consider 500 or 600V electrolytics. OR some kind of device to step the AC line voltage to 110.
Also, be careful about substituting another heavy-duty rectifier for the 5V4, as the 5V4 has a cathode on one of the filament pins.
Stewart Warner R1495A - by 7estatdef - 01-04-2013, 05:42 PM
RE: Stewart Warner R1495A - by Ron Ramirez - 01-04-2013, 06:43 PM
RE: Stewart Warner R1495A - by 7estatdef - 01-04-2013, 06:49 PM
RE: Stewart Warner R1495A - by Arran - 01-04-2013, 11:40 PM
RE: Stewart Warner R1495A - by murf - 01-19-2013, 09:46 PM
RE: Stewart Warner R1495A - by TA Forbes - 01-19-2013, 10:44 PM
RE: Stewart Warner R1495A - by Arran - 01-23-2013, 11:53 PM
RE: Stewart Warner R1495A - by TA Forbes - 01-24-2013, 03:12 PM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 4046 online users. [Complete List]
» 2 Member(s) | 4044 Guest(s)
