46-1201 Bing Crosby - Feet? Screws? Clips for Bottom?
The bottom frame on mine, which the record player mounts to, is stamped out sheet steel. The feet were held on by sheet metal type screws, I believe approximately near the corners of the Masonite bottom, that may be why there does not appear to be any threads. My 76A is somewhat buried right now so someone else may have one easier to get out an examine. The feet were something like 1/2 to 5/8'' in size.
RE: 46-1201 Bing Crosby - Feet? Screws? Clips for Bottom? - by Arran - 01-27-2013, 01:54 AM
New member
Philco 630csx power cord
New member
There are currently 2595 online users. [Complete List]
» 2 Member(s) | 2593 Guest(s)
