46-1201 Bing Crosby - Feet? Screws? Clips for Bottom?
Thanks Arran. When I was measuring threads, I was measuring the holes in the M-7's metal frame, not the wooden board/cover, as that's where any screw, machine or wood, would have to pass through and grab.
Do you recall if your passthrough bumper feet had a taper? Also, did you mean 1/2" - 5/8" in diameter or height?
RE: 46-1201 Bing Crosby - Feet? Screws? Clips for Bottom? - by awc71 - 01-27-2013, 02:39 AM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2568 online users. [Complete List]
» 2 Member(s) | 2566 Guest(s)
