42-761EZ Chassis Restoration
If you wanted to you could use a diode in series with pilot lamp to drop the voltage by half. Then you would just need to loose 60v. Or if you are a math major you could use a paper cap to drop the ac voltage down.
42-761EZ Chassis Restoration - by Ron Ramirez - 01-22-2013, 05:52 PM
RE: 42-761EZ Chassis Restoration - by Steve Davis - 01-22-2013, 07:00 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-23-2013, 09:03 PM
RE: 42-761EZ Chassis Restoration - by Arran - 01-24-2013, 12:13 AM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-24-2013, 09:07 PM
RE: 42-761EZ Chassis Restoration - by brownie45 - 01-26-2013, 06:25 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-26-2013, 07:16 PM
RE: 42-761EZ Chassis Restoration - by brownie45 - 01-26-2013, 09:10 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-26-2013, 09:15 PM
RE: 42-761EZ Chassis Restoration - by Eliot Ness - 01-27-2013, 02:01 PM
RE: 42-761EZ Chassis Restoration - by morzh - 01-27-2013, 02:14 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-27-2013, 02:37 PM
RE: 42-761EZ Chassis Restoration - by Eliot Ness - 01-27-2013, 03:42 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-27-2013, 08:29 PM
RE: 42-761EZ Chassis Restoration - by 7estatdef - 01-27-2013, 09:44 PM
RE: 42-761EZ Chassis Restoration - by Arran - 01-28-2013, 01:36 AM
RE: 42-761EZ Chassis Restoration - by Eliot Ness - 01-30-2013, 12:36 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-30-2013, 05:17 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-30-2013, 08:45 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-31-2013, 09:14 PM
RE: 42-761EZ Chassis Restoration - by Eliot Ness - 02-01-2013, 01:04 PM
RE: 42-761EZ Chassis Restoration - by codefox1 - 02-01-2013, 01:50 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-01-2013, 05:37 PM
RE: 42-761EZ Chassis Restoration - by codefox1 - 02-01-2013, 05:54 PM
RE: 42-761EZ Chassis Restoration - by brownie45 - 02-01-2013, 06:17 PM
RE: 42-761EZ Chassis Restoration - by Arran - 02-01-2013, 10:38 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-02-2013, 05:20 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-02-2013, 10:14 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-05-2013, 07:54 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-05-2013, 08:07 PM
RE: 42-761EZ Chassis Restoration - by Eliot Ness - 02-05-2013, 08:48 PM
RE: 42-761EZ Chassis Restoration - by w4rtc - 02-05-2013, 09:46 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-06-2013, 10:58 AM
RE: 42-761EZ Chassis Restoration - by PhilcoMike - 02-06-2013, 11:49 AM
RE: 42-761EZ Chassis Restoration - by klondike98 - 02-06-2013, 02:01 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-10-2013, 08:08 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-10-2013, 08:13 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-10-2013, 08:23 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-17-2013, 09:19 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-18-2013, 05:01 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-18-2013, 08:17 PM
RE: 42-761EZ Chassis Restoration - by Arran - 02-18-2013, 08:28 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-19-2013, 09:36 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-20-2013, 06:29 AM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-20-2013, 11:19 AM
RE: 42-761EZ Chassis Restoration - by codefox1 - 02-20-2013, 02:38 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-20-2013, 06:00 PM
RE: 42-761EZ Chassis Restoration - by codefox1 - 02-20-2013, 06:50 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-20-2013, 07:33 PM
RE: 42-761EZ Chassis Restoration - by GarySP - 02-20-2013, 10:28 PM
RE: 42-761EZ Chassis Restoration - by Arran - 02-20-2013, 10:48 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-21-2013, 08:54 AM
RE: 42-761EZ Chassis Restoration - by 7estatdef - 02-21-2013, 10:04 AM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-21-2013, 05:10 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
