38-116 repair help
Terry, let me know how you pull that floating section out. I have a 38-116 chassis on my bench now and performance is great but one of those dang caps I see no way to get to. It's a .05 in the rear section of the RF module. Pined up against the chassis and the only little part I can see fortunately showed the value. Clueless as to how to get to it. The radio works but it is a problem just waiting to raise it's ugly head.
Jerry
38-116 repair help - by murf - 01-27-2013, 06:20 PM
RE: 38-116 repair help - by dixierat - 01-27-2013, 07:58 PM
RE: 38-116 repair help - by 7estatdef - 01-27-2013, 09:28 PM
RE: 38-116 repair help - by jerryhawthorne - 01-28-2013, 10:52 PM
RE: 38-116 repair help - by murf - 01-28-2013, 11:13 PM
RE: 38-116 repair help - by morzh - 01-28-2013, 11:22 PM
RE: 38-116 repair help - by 7estatdef - 01-28-2013, 11:29 PM
RE: 38-116 repair help - by SteveJB - 01-28-2013, 11:30 PM
RE: 38-116 repair help - by jerryhawthorne - 01-28-2013, 11:56 PM
RE: 38-116 repair help - by Phlogiston - 01-29-2013, 04:23 AM
RE: 38-116 repair help - by jerryhawthorne - 01-29-2013, 11:55 PM
RE: 38-116 repair help - by Arran - 01-30-2013, 01:57 AM
RE: 38-116 repair help - by Ron Ramirez - 01-30-2013, 09:12 AM
RE: 38-116 repair help - by Chuck Schwark - 01-30-2013, 10:25 AM
RE: 38-116 repair help - by murf - 01-30-2013, 10:59 AM
RE: 38-116 repair help - by Phlogiston - 01-30-2013, 10:20 PM
RE: 38-116 repair help - by Ron Ramirez - 01-31-2013, 06:42 AM
RE: 38-116 repair help - by jerryhawthorne - 01-31-2013, 06:37 PM
RE: 38-116 repair help - by murf - 01-31-2013, 06:56 PM
RE: 38-116 repair help - by jerryhawthorne - 01-31-2013, 07:06 PM
RE: 38-116 repair help - by murf - 01-31-2013, 08:41 PM
RE: 38-116 repair help - by Ron Ramirez - 01-31-2013, 09:30 PM
RE: 38-116 repair help - by Phlogiston - 01-31-2013, 10:48 PM
RE: 38-116 repair help - by jerryhawthorne - 02-01-2013, 12:03 AM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
