Admiral 7T10
Agree with Jerry. You can test the osc coil in circuit all three pins should have have continuity to each other , a low resistance in the order of 10 ohms or less. If not that's your problem. Universal replacement are available from AES.
Got a 7T04 in the basement myself.
Admiral 7T10 - by jph14 - 01-28-2013, 06:24 PM
RE: Admiral 7T10 - by jerryhawthorne - 01-29-2013, 04:47 PM
RE: Admiral 7T10 - by 7estatdef - 01-29-2013, 05:59 PM
RE: Admiral 7T10 - by jph14 - 01-29-2013, 07:16 PM
RE: Admiral 7T10 - by jerryhawthorne - 01-29-2013, 07:21 PM
RE: Admiral 7T10 - by 7estatdef - 01-29-2013, 08:55 PM
RE: Admiral 7T10 - by jerryhawthorne - 01-29-2013, 10:16 PM
RE: Admiral 7T10 - by jerryhawthorne - 01-30-2013, 03:30 PM
RE: Admiral 7T10 - by jph14 - 01-30-2013, 03:47 PM
RE: Admiral 7T10 - by 7estatdef - 01-30-2013, 07:16 PM
There are currently 4348 online users. [Complete List]
» 2 Member(s) | 4346 Guest(s)
