philco 42-1012
I would check both output transformers first before pulling the spare one, it seems to be a recurring problem with most of these sets. The good news is that you can likely pull a good one from a scrap chassis of another brand that also has push pull outputs. Any transformer that is used with 6F6s, 42s, 6V6s, 6BQ5s should work fine, 6K6s and 41s not so much.
philco 42-1012 - by murf - 01-06-2013, 12:21 AM
RE: philco 42-1012 - by TA Forbes - 01-06-2013, 02:41 AM
RE: philco 42-1012 - by shawn - 01-16-2013, 09:48 PM
RE: philco 42-1012 - by murf - 01-16-2013, 10:00 PM
RE: philco 42-1012 - by TA Forbes - 01-16-2013, 10:02 PM
RE: philco 42-1012 - by murf - 01-16-2013, 11:33 PM
RE: philco 42-1012 - by murf - 01-24-2013, 11:53 PM
RE: philco 42-1012 - by TA Forbes - 01-25-2013, 12:44 AM
RE: philco 42-1012 - by Arran - 01-25-2013, 03:00 AM
RE: philco 42-1012 - by murf - 01-27-2013, 06:13 PM
RE: philco 42-1012 - by Electrothaumaturgist - 01-30-2013, 04:54 PM
RE: philco 42-1012 - by Arran - 01-30-2013, 10:24 PM
RE: philco 42-1012 - by murf - 01-30-2013, 10:45 PM
RE: philco 42-1012 - by codefox1 - 01-31-2013, 02:06 PM
RE: philco 42-1012 - by murf - 01-31-2013, 06:19 PM
RE: philco 42-1012 - by Electrothaumaturgist - 01-31-2013, 09:02 PM
RE: philco 42-1012 - by murf - 01-31-2013, 09:14 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
There are currently 3371 online users. [Complete List]
» 2 Member(s) | 3369 Guest(s)
