  • 2 Vote(s) - 2.5 Average
Philco 40-140 Field Coil Replacement
#50
As I said, the transformer should not run hotter with the larger cap. If it does, then something is either drawing more current than it should, or else the transformer was already marginal (that is, possibly damaged) from old, partially shorted electrolytics and continued operation in that condition.
Philco 40-140 Field Coil Replacement - by radiola - 09-05-2012, 12:21 AM
RE: Philco 40-140 Field Coil Replacement - by Ron Ramirez - 02-01-2013, 06:07 AM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
There are currently 3350 online users. [Complete List]
» 1 Member(s) | 3349 Guest(s)
