Voltage dropping resistor question
The obvious answer is something less than 23 ohms, but of course you already know that! Without knowing a little more, like what your line voltage was to start all we could do is guess at what lesser value you could try.
As to the shadow-meter performance, the lower line voltage could very well be a problem, but have you replaced all the caps and any resistors that are out of range, especially in the shadow-meter/a.v.c. circuit? If so I would run the set on a variac at 110-115 and see how the set and shadow-meter perform. Below are a couple of helpful links on shadow-meters, the first one will help you visualize how the meter works in relation to the a.v.c.:
http://www.philcorepairbench.com/tips/svctip01a.htm
http://www.philcorepairbench.com/tips/svctip01.htm
RE: Voltage dropping resistor question - by morzh - 01-31-2013, 09:16 PM
RE: Voltage dropping resistor question - by Eliot Ness - 02-01-2013, 12:13 PM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 7549 online users. [Complete List]
» 1 Member(s) | 7548 Guest(s)
