philco 42-355 no reception
radio had limited reception only w/external ant. Changed paper and electrolytic caps. Now only works w/pushbutton presets, no manual tuning.Then even stops getting anything w/pushbuttons after 2-3min.warmup.
philco 42-355 no reception - by sparkin' chassis - 02-02-2013, 10:45 PM
RE: philco 42-355 no reception - by 7estatdef - 02-03-2013, 09:40 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
