1936? model 84 resistor
#31
Hi Jim,
I'm pretty sure it's grounded internally but just to be sure you can check it with an ohm meter. Usually what happens is without a gnd connect to the set the volume control doesn't have much of an effect at all. Plays loud all the time. Did you try reversing the coil winding?
1936? model 84 resistor - by brownie45 - 01-22-2013, 03:48 PM
RE: 1936? model 84 resistor - by Ron Ramirez - 01-22-2013, 07:30 PM
RE: 1936? model 84 resistor - by brownie45 - 01-22-2013, 09:10 PM
RE: 1936? model 84 resistor - by 7estatdef - 01-26-2013, 09:30 AM
RE: 1936? model 84 resistor - by Ron Ramirez - 01-26-2013, 10:02 AM
RE: 1936? model 84 resistor - by Ron Ramirez - 01-26-2013, 10:03 AM
RE: 1936? model 84 resistor - by brownie45 - 01-26-2013, 02:50 PM
RE: 1936? model 84 resistor - by codefox1 - 01-26-2013, 03:18 PM
RE: 1936? model 84 resistor - by Ron Ramirez - 01-26-2013, 07:19 PM
RE: 1936? model 84 resistor - by brownie45 - 01-26-2013, 09:04 PM
RE: 1936? model 84 resistor - by Ron Ramirez - 01-26-2013, 09:10 PM
RE: 1936? model 84 resistor - by 7estatdef - 01-26-2013, 09:10 PM
RE: 1936? model 84 resistor - by Ron Ramirez - 01-26-2013, 09:12 PM
RE: 1936? model 84 resistor - by brownie45 - 01-26-2013, 10:41 PM
RE: 1936? model 84 resistor - by 7estatdef - 01-27-2013, 09:59 AM
RE: 1936? model 84 resistor - by brownie45 - 01-28-2013, 04:55 PM
RE: 1936? model 84 resistor - by 7estatdef - 01-28-2013, 11:48 PM
RE: 1936? model 84 resistor - by brownie45 - 01-29-2013, 07:38 AM
RE: 1936? model 84 resistor - by Ron Ramirez - 01-29-2013, 10:52 AM
RE: 1936? model 84 resistor - by brownie45 - 01-29-2013, 02:40 PM
RE: 1936? model 84 resistor - by klondike98 - 01-29-2013, 03:00 PM
RE: 1936? model 84 resistor - by Ron Ramirez - 01-29-2013, 03:16 PM
RE: 1936? model 84 resistor - by brownie45 - 01-29-2013, 03:26 PM
RE: 1936? model 84 resistor - by 7estatdef - 01-29-2013, 05:37 PM
RE: 1936? model 84 resistor - by brownie45 - 01-29-2013, 06:39 PM
RE: 1936? model 84 resistor - by 7estatdef - 01-29-2013, 08:48 PM
RE: 1936? model 84 resistor - by brownie45 - 02-01-2013, 03:49 PM
RE: 1936? model 84 resistor - by brownie45 - 02-01-2013, 04:37 PM
RE: 1936? model 84 resistor - by 7estatdef - 02-01-2013, 11:00 PM
RE: 1936? model 84 resistor - by brownie45 - 02-02-2013, 08:10 AM
RE: 1936? model 84 resistor - by 7estatdef - 02-03-2013, 10:07 PM
RE: 1936? model 84 resistor - by brownie45 - 02-04-2013, 08:01 AM
RE: 1936? model 84 resistor - by 7estatdef - 02-04-2013, 10:00 AM
RE: 1936? model 84 resistor - by brownie45 - 02-04-2013, 11:19 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
