voltage on tube heater 46-350
To add to Dennis's comments you probably want to use an analog meter just easier to read. It will be set on the low setting for AC volts.
A bucking transformers an easy way to knock down the line voltage.
voltage on tube heater 46-350 - by mountain man - 02-02-2013, 01:38 PM
RE: voltage on tube heater 46-350 - by TA Forbes - 02-06-2013, 10:30 PM
RE: voltage on tube heater 46-350 - by codefox1 - 02-06-2013, 11:32 PM
RE: voltage on tube heater 46-350 - by Arran - 02-06-2013, 11:37 PM
voltage on tube heater 46-350 - by 7estatdef - 02-03-2013, 10:26 PM
voltage on tube heater 46-350 - by mountain man - 02-04-2013, 11:06 AM
voltage on tube heater 46-350 - by mountain man - 02-04-2013, 11:25 AM
RE: voltage on tube heater 46-350 - by Conelrad - 02-04-2013, 12:56 PM
RE: voltage on tube heater 46-350 - by 7estatdef - 02-04-2013, 02:16 PM
RE: voltage on tube heater 46-350 - by Arran - 02-04-2013, 08:45 PM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 10122 online users. [Complete List]
» 2 Member(s) | 10120 Guest(s)
