Tubes
Checking the NJ7P Tube Database at http://www.nj7p.org/Tube.php , the 7n7 is a substitute for the 7af7 so if its working OK I'd leave it.
Tubes - by philco4me - 02-05-2013, 11:29 AM
RE: Tubes - by John R - 02-05-2013, 01:38 PM
RE: Tubes - by klondike98 - 02-05-2013, 01:45 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3975 online users. [Complete List]
» 1 Member(s) | 3974 Guest(s)
