philco 42-355 no reception
Checked oscillator coil tests good. when connected to an external antenna there is an area around 600 on the am dial that receives static with the volume turned all the way up.
philco 42-355 no reception - by sparkin' chassis - 02-02-2013, 10:45 PM
RE: philco 42-355 no reception - by 7estatdef - 02-03-2013, 09:40 AM
RE: philco 42-355 no reception - by sparkin' chassis - 02-05-2013, 06:24 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
