42-761EZ Chassis Restoration
#33
I suspect, as you do, that there was a rubber piece between the two U brackets. If it isn't too hard to remove one of the shafts it would be easy enough to cut a rubber piece to fit. Use something like a thick chassis washer or whatever you can find in your shop or local hardware store.
If it is hard to remove a shaft, then experiment with different sizes of rubber cut to shape and try wedging a piece in between the brackets; that might require a softer piece of rubber to be pliable enough.
You could try putting a piece of tape part-way around the two U brackets and fill the space with RTV Silicone, but I'm not sure how well it would hold up, I suspect it might not do very well.
42-761EZ Chassis Restoration - by Ron Ramirez - 01-22-2013, 05:52 PM
RE: 42-761EZ Chassis Restoration - by Steve Davis - 01-22-2013, 07:00 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-23-2013, 09:03 PM
RE: 42-761EZ Chassis Restoration - by Arran - 01-24-2013, 12:13 AM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-24-2013, 09:07 PM
RE: 42-761EZ Chassis Restoration - by brownie45 - 01-26-2013, 06:25 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-26-2013, 07:16 PM
RE: 42-761EZ Chassis Restoration - by brownie45 - 01-26-2013, 09:10 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-26-2013, 09:15 PM
RE: 42-761EZ Chassis Restoration - by Eliot Ness - 01-27-2013, 02:01 PM
RE: 42-761EZ Chassis Restoration - by morzh - 01-27-2013, 02:14 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-27-2013, 02:37 PM
RE: 42-761EZ Chassis Restoration - by Eliot Ness - 01-27-2013, 03:42 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-27-2013, 08:29 PM
RE: 42-761EZ Chassis Restoration - by 7estatdef - 01-27-2013, 09:44 PM
RE: 42-761EZ Chassis Restoration - by Arran - 01-28-2013, 01:36 AM
RE: 42-761EZ Chassis Restoration - by Eliot Ness - 01-30-2013, 12:36 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-30-2013, 05:17 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-30-2013, 08:45 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 01-31-2013, 09:14 PM
RE: 42-761EZ Chassis Restoration - by Eliot Ness - 02-01-2013, 01:04 PM
RE: 42-761EZ Chassis Restoration - by codefox1 - 02-01-2013, 01:50 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-01-2013, 05:37 PM
RE: 42-761EZ Chassis Restoration - by codefox1 - 02-01-2013, 05:54 PM
RE: 42-761EZ Chassis Restoration - by brownie45 - 02-01-2013, 06:17 PM
RE: 42-761EZ Chassis Restoration - by Arran - 02-01-2013, 10:38 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-02-2013, 05:20 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-02-2013, 10:14 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-05-2013, 07:54 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-05-2013, 08:07 PM
RE: 42-761EZ Chassis Restoration - by Eliot Ness - 02-05-2013, 08:48 PM
RE: 42-761EZ Chassis Restoration - by w4rtc - 02-05-2013, 09:46 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-06-2013, 10:58 AM
RE: 42-761EZ Chassis Restoration - by PhilcoMike - 02-06-2013, 11:49 AM
RE: 42-761EZ Chassis Restoration - by klondike98 - 02-06-2013, 02:01 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-10-2013, 08:08 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-10-2013, 08:13 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-10-2013, 08:23 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-17-2013, 09:19 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-18-2013, 05:01 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-18-2013, 08:17 PM
RE: 42-761EZ Chassis Restoration - by Arran - 02-18-2013, 08:28 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-19-2013, 09:36 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-20-2013, 06:29 AM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-20-2013, 11:19 AM
RE: 42-761EZ Chassis Restoration - by codefox1 - 02-20-2013, 02:38 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-20-2013, 06:00 PM
RE: 42-761EZ Chassis Restoration - by codefox1 - 02-20-2013, 06:50 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-20-2013, 07:33 PM
RE: 42-761EZ Chassis Restoration - by GarySP - 02-20-2013, 10:28 PM
RE: 42-761EZ Chassis Restoration - by Arran - 02-20-2013, 10:48 PM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-21-2013, 08:54 AM
RE: 42-761EZ Chassis Restoration - by 7estatdef - 02-21-2013, 10:04 AM
RE: 42-761EZ Chassis Restoration - by Ron Ramirez - 02-21-2013, 05:10 PM
Users browsing this thread: 16 Guest(s)
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 8536 online users. [Complete List]
» 2 Member(s) | 8534 Guest(s)
