Philco 60 Transformer issue
Hi TexasRocker:
I did take a reading with the 80 Rect. out of the set and placed the meter probes across the two plate pins There I got a high reading of 786 volts AC. which to me looked high and promted me to post this question.
However I did not do the seperate reading of each plates with the negative probe ground to chassie. I will try this.
I am a little confused once I get these 2 plate readings. Can you explain again from this point?
PS I do have a tube booklet with tube info and diagrams.
Thanks
John
Philco 60 Transformer issue - by Guest - 10-01-2007, 01:31 AM
[No subject] - by rickd - 10-02-2007, 09:20 AM
[No subject] - by Texasrocker - 10-02-2007, 11:07 PM
Philco 60 transformer issue - by Guest - 10-03-2007, 12:45 AM
Transformer issue Philco - by Guest - 10-03-2007, 01:10 AM
[No subject] - by Ron Ramirez - 10-03-2007, 07:06 AM
[No subject] - by Texasrocker - 10-03-2007, 11:53 PM
