Philco model 18 (code 121) - HELP!
Threads: 1
City: Sunny Michigan
[Video: http://www.youtube.com/watch?v=PJRewmPhnZM]
I've attached the video that is giving me the crazy 'train' doppler sound.
I also have another much more boring video showing what I've replaced on this radio etc. try not to fall asleep.
And here is that video
[Video: http://www.youtube.com/watch?v=E5-H1lRdh1o]
Thanks.
RE: Philco model 18 (code 121) - HELP! - by Pithicus999 - 02-07-2013, 11:18 PM
Philco 91 Tuning Condenser
I thought you meant the actual dial....there are rivets.morzh — 08:42 PM |
This is what I meant.morzh — 08:37 PM |
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
There are currently 6989 online users. [Complete List] » 1 Member(s) | 6988 Guest(s)
