Philco 95 cap questions ( more)
Thanks, I had for got about the cap+ resistor together
Philco 95 cap questions ( more) - by simplex1040 - 02-10-2013, 02:49 PM
RE: Philco 95 cap questions ( more) - by simplex1040 - 02-10-2013, 09:52 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
