A 1937 Accessory Philco Antenna
Very nice Gene! It is interesting how many were purchased and never used. I have a 1938 that is very similar to your 1937 antenna, and I have this one from 1939 or 1940. I'd like to use one and
see how well they perform Icon_biggrin
RE: A 1937 Accessory Philco Antenna - by thirtiesradio - 02-11-2013, 01:27 AM
RE: A 1937 Accessory Philco Antenna - by Raleigh - 03-14-2013, 01:25 PM
Philco 91 Tuning Condenser
