Could someone pat me on the back?
Quote:DK, I replaced at ruinous expense two of those tubes that both measured between 8 and 10% on my cheap tube tester with NOS tubes. No real difference in performance. Of course they were "matched" for low emission!
So, is the temperature difference between them accounted for by their different emission quality?
Could someone pat me on the back? - by DKinYORKpa - 02-10-2013, 12:25 PM
RE: Could someone pat me on the back? - by Eric T - 02-10-2013, 03:39 PM
RE: Could someone pat me on the back? - by morzh - 02-10-2013, 04:55 PM
RE: Could someone pat me on the back? - by Arran - 02-10-2013, 07:48 PM
RE: Could someone pat me on the back? - by morzh - 02-10-2013, 10:46 PM
RE: Could someone pat me on the back? - by FXpert - 02-11-2013, 07:13 AM
RE: Could someone pat me on the back? - by DKinYORKpa - 02-11-2013, 01:06 PM
RE: Could someone pat me on the back? - by morzh - 02-12-2013, 12:14 AM
RE: Could someone pat me on the back? - by morzh - 02-14-2013, 08:56 PM
RE: Could someone pat me on the back? - by morzh - 02-15-2013, 08:34 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
