1936 610 restoration
Hi Guys!
Long time lurker, first time poster.
I picked up a 1936 610 recently (sigh, buried under a bench in a car port)
the chassis is about done and I'm working on the cabinet and I need a little advice. after the broken pieces were repaired it was all cleaned up.. I used a lighter walnut to stain the bleached sections and it worked out well.. but the whole front is about as dark as the outer portion should be. I used grain filler on the sides (walnut from mohawk) and it's Really dark. I'm thinking I'll need to use a pigment toner on the sides because all the nicks and dings, which are now filled with grain filler. the front looks decent enough to use a dye toner on.. I'm looking for some advice on which colors to use. my local hardware store carries the entire line of mohawk everything.. so obtaining it is easy.
[Image: http://farm9.staticflickr.com/8241/84675...6675_b.jpg]
P1000757 by bfrohwein, on Flickr
[Image: http://farm9.staticflickr.com/8234/84664...a6c0_b.jpg]
P1000756 by bfrohwein, on Flickr
second question is about decals.. Does anyone know which decal set from Radio Daze I should order? I orderd a DCL-PH1 but I'm not sure if the three philco decalls on the lower left are the correct ones or not.
DCL-PH1 @ radiodaze
any info any might have would be appreciated!
Thanks again
Bret
1936 610 restoration - by bfrohwein - 02-12-2013, 02:14 AM
RE: 1936 610 restoration - by Ron Ramirez - 02-12-2013, 12:33 PM
RE: 1936 610 restoration - by Ron Ramirez - 02-12-2013, 01:00 PM
RE: 1936 610 restoration - by Steve Davis - 02-12-2013, 03:37 PM
RE: 1936 610 restoration - by bfrohwein - 02-12-2013, 03:53 PM
RE: 1936 610 restoration - by Ron Ramirez - 02-12-2013, 04:42 PM
RE: 1936 610 restoration - by bfrohwein - 02-12-2013, 09:10 PM
RE: 1936 610 restoration - by Steve Davis - 02-13-2013, 12:10 AM
RE: 1936 610 restoration - by bfrohwein - 02-17-2013, 12:36 PM
RE: 1936 610 restoration - by Ron Ramirez - 02-17-2013, 07:50 PM
RE: 1936 610 restoration - by bfrohwein - 02-17-2013, 09:33 PM
RE: 1936 610 restoration - by bfrohwein - 03-28-2013, 08:43 PM
RE: 1936 610 restoration - by TimC - 03-28-2013, 09:01 PM
RE: 1936 610 restoration - by bfrohwein - 03-28-2013, 11:22 PM
RE: 1936 610 restoration - by Ron Ramirez - 03-29-2013, 05:31 AM
RE: 1936 610 restoration - by bfrohwein - 03-29-2013, 09:51 AM
RE: 1936 610 restoration - by Chris Cusick - 03-29-2013, 05:24 PM
RE: 1936 610 restoration - by Art Hoch - 03-29-2013, 09:35 PM
RE: 1936 610 restoration - by bfrohwein - 05-30-2013, 04:15 PM
RE: 1936 610 restoration - by Art Hoch - 05-30-2013, 04:57 PM
RE: 1936 610 restoration - by bfrohwein - 05-31-2013, 02:22 AM
There are currently 8963 online users. [Complete List]
» 3 Member(s) | 8960 Guest(s)
