1936 610 restoration
You don't want the PH1 decal sheet, it isn't correct for the 1932-36 Philco models. You want the PH8:
http://www.radiodaze.com/product/6049.aspx
1936 610 restoration - by bfrohwein - 02-12-2013, 02:14 AM
RE: 1936 610 restoration - by Ron Ramirez - 02-12-2013, 12:33 PM
RE: 1936 610 restoration - by Ron Ramirez - 02-12-2013, 01:00 PM
RE: 1936 610 restoration - by Steve Davis - 02-12-2013, 03:37 PM
RE: 1936 610 restoration - by bfrohwein - 02-12-2013, 03:53 PM
RE: 1936 610 restoration - by Ron Ramirez - 02-12-2013, 04:42 PM
RE: 1936 610 restoration - by bfrohwein - 02-12-2013, 09:10 PM
RE: 1936 610 restoration - by Steve Davis - 02-13-2013, 12:10 AM
RE: 1936 610 restoration - by bfrohwein - 02-17-2013, 12:36 PM
RE: 1936 610 restoration - by Ron Ramirez - 02-17-2013, 07:50 PM
RE: 1936 610 restoration - by bfrohwein - 02-17-2013, 09:33 PM
RE: 1936 610 restoration - by bfrohwein - 03-28-2013, 08:43 PM
RE: 1936 610 restoration - by TimC - 03-28-2013, 09:01 PM
RE: 1936 610 restoration - by bfrohwein - 03-28-2013, 11:22 PM
RE: 1936 610 restoration - by Ron Ramirez - 03-29-2013, 05:31 AM
RE: 1936 610 restoration - by bfrohwein - 03-29-2013, 09:51 AM
RE: 1936 610 restoration - by Chris Cusick - 03-29-2013, 05:24 PM
RE: 1936 610 restoration - by Art Hoch - 03-29-2013, 09:35 PM
RE: 1936 610 restoration - by bfrohwein - 05-30-2013, 04:15 PM
RE: 1936 610 restoration - by Art Hoch - 05-30-2013, 04:57 PM
RE: 1936 610 restoration - by bfrohwein - 05-31-2013, 02:22 AM
There are currently 8748 online users. [Complete List]
» 2 Member(s) | 8746 Guest(s)
