1936 610 restoration
oh, wow.. even when much of the wood was exposed to weather and looked like it? I should've had before pictures. I will ask here first next time. apparently I listened to all the wrong people. I've got the above toners already, so that's good.. thanks for the decal info, it was a bit hard to tell from pictures I saw online which was correct.
Was the grain filler not right to use? the sides were really weather damaged and splintered easily and I could fit a fingernail in some of the grain lines.
I'll get rid of the blue painters tape I bought, thank you for bringing it up, because I was very hesitant about whether it was the right one to buy. :-)
Thank you so much for this information. I'm Very glad I decided to stop what I was doing and come here for advice. I'm also hoping, when I get better at this, you guys will be generous in helping me with my big find late last year. I stumbled across a 1935 16B Shouldered tombstone with the original finish intact.
Thanks again!
1936 610 restoration - by bfrohwein - 02-12-2013, 02:14 AM
RE: 1936 610 restoration - by Ron Ramirez - 02-12-2013, 12:33 PM
RE: 1936 610 restoration - by Ron Ramirez - 02-12-2013, 01:00 PM
RE: 1936 610 restoration - by Steve Davis - 02-12-2013, 03:37 PM
RE: 1936 610 restoration - by bfrohwein - 02-12-2013, 03:53 PM
RE: 1936 610 restoration - by Ron Ramirez - 02-12-2013, 04:42 PM
RE: 1936 610 restoration - by bfrohwein - 02-12-2013, 09:10 PM
RE: 1936 610 restoration - by Steve Davis - 02-13-2013, 12:10 AM
RE: 1936 610 restoration - by bfrohwein - 02-17-2013, 12:36 PM
RE: 1936 610 restoration - by Ron Ramirez - 02-17-2013, 07:50 PM
RE: 1936 610 restoration - by bfrohwein - 02-17-2013, 09:33 PM
RE: 1936 610 restoration - by bfrohwein - 03-28-2013, 08:43 PM
RE: 1936 610 restoration - by TimC - 03-28-2013, 09:01 PM
RE: 1936 610 restoration - by bfrohwein - 03-28-2013, 11:22 PM
RE: 1936 610 restoration - by Ron Ramirez - 03-29-2013, 05:31 AM
RE: 1936 610 restoration - by bfrohwein - 03-29-2013, 09:51 AM
RE: 1936 610 restoration - by Chris Cusick - 03-29-2013, 05:24 PM
RE: 1936 610 restoration - by Art Hoch - 03-29-2013, 09:35 PM
RE: 1936 610 restoration - by bfrohwein - 05-30-2013, 04:15 PM
RE: 1936 610 restoration - by Art Hoch - 05-30-2013, 04:57 PM
RE: 1936 610 restoration - by bfrohwein - 05-31-2013, 02:22 AM
There are currently 10361 online users. [Complete List]
» 1 Member(s) | 10360 Guest(s)
