It's Alive!!!
I'm assuming you have looked at the info on Philco Repair Bench for the adjustments for the BOL if you say you've adjusted the light beam. I have a 41-629 with the BOL changer that I got to work pretty good. I ended up replacing the old cell with a cell from a money changer and had plenty of output. I don't know how much voltage your old cell is developing, or if you have the original lamp (I do). After all of my restoration to the chassis and changer I adjusted a compensator in the radio (for the BOL) so that when I swithced between the radio broadcast and the recording the volume was about the same. One advantage with the cell I used for replacement is the intensity of the lamp (RF from radio) is quite a bit dimmer and I would assume prolong the life of the extinct lamp.
I looked at the schematic for the 608 and I didn't see where any adjustments are for the BOL. They refer to the index.
It's Alive!!! - by Mr Grumpy - 02-11-2013, 04:28 PM
RE: It's Alive!!! - by klondike98 - 02-11-2013, 05:09 PM
RE: It's Alive!!! - by Mr Grumpy - 02-12-2013, 01:21 PM
RE: It's Alive!!! - by jerryhawthorne - 02-12-2013, 01:35 PM
RE: It's Alive!!! - by marv - 02-12-2013, 04:37 PM
RE: It's Alive!!! - by jerryhawthorne - 02-12-2013, 05:58 PM
RE: It's Alive!!! - by Mr Grumpy - 02-13-2013, 12:23 AM
RE: It's Alive!!! - by Eric T - 02-14-2013, 10:20 PM
RE: It's Alive!!! - by jerryhawthorne - 02-14-2013, 10:31 PM
RE: It's Alive!!! - by wa2ise - 02-14-2013, 11:50 PM
RE: It's Alive!!! - by TA Forbes - 02-15-2013, 01:24 AM
RE: It's Alive!!! - by Mr Grumpy - 02-16-2013, 09:49 PM
RE: It's Alive!!! - by Mr Grumpy - 02-27-2013, 01:09 PM
RE: It's Alive!!! - by Mr Grumpy - 03-20-2013, 09:48 PM
RE: It's Alive!!! - by 7estatdef - 03-22-2013, 09:47 PM
RE: It's Alive!!! - by Mr Grumpy - 03-22-2013, 10:58 PM
RE: It's Alive!!! - by Arran - 03-22-2013, 11:18 PM
RE: It's Alive!!! - by Mr Grumpy - 03-22-2013, 11:55 PM
RE: It's Alive!!! - by Arran - 03-23-2013, 03:18 AM
RE: It's Alive!!! - by Steve Davis - 03-23-2013, 02:27 PM
RE: It's Alive!!! - by 7estatdef - 03-23-2013, 06:19 PM
RE: It's Alive!!! - by Mr Grumpy - 03-23-2013, 10:01 PM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 10910 online users. [Complete List]
» 2 Member(s) | 10908 Guest(s)
