37-690 band 2 troubles
I had a 37-675 with a bad band 2 oscillator coil. I ended up pulling the coil out and rewinding it. I'm sure it is possible to rewind the coil on a 37-690, it just isn't very fun. From the schematic, the 37-675 and 37-690 use the same band 2 oscillator coil. IIRC, the 37-675 also used the same sub-chassis as the 37-116. I'll try to remember to look to see if I have notes from when I rewound that coil.
Sean
WØKPX
37-690 band 2 troubles - by wonderwrench - 10-14-2007, 11:59 PM
[No subject] - by Sean - 10-15-2007, 09:12 AM
[No subject] - by wonderwrench - 10-15-2007, 01:36 PM
[No subject] - by Carl Travis - 10-15-2007, 03:50 PM
[No subject] - by Ron Ramirez - 10-15-2007, 05:51 PM
Coil rewinding for lower bands - by AI2V - 10-15-2007, 07:06 PM
[No subject] - by wonderwrench - 10-15-2007, 07:35 PM
There are currently 5023 online users. [Complete List]
» 4 Member(s) | 5019 Guest(s)
AvatarAvatarAvatarAvatar
