38-4 restoration need advice/ help
Hi everyone, I am a new member with two 38-4 consoles. One is working fine with a recent recap (not by myself), and the other I have just recapped myself, and now have many questions so here goes... After replacing the paper tubulars and the elctrolytics, I reused the Mica caps, i tested socket voltages per bulletin #281, and noticed the DC readings were high. The power transformer is taller than my working set, and according to the part number stamped on it I have a 115v 25/40 hertz xfmr. Should I stop here and locate a 60hertz transformer? I do get recption on both bands, the volume level is low compared to the working set as well.
38-4 restoration need advice/ help - by conroyp - 02-12-2013, 10:00 PM
RE: 38-4 restoration need advice/ help - by Arran - 02-15-2013, 01:28 AM
RE: 38-4 restoration need advice/ help - by morzh - 02-15-2013, 07:26 PM
RE: 38-4 restoration need advice/ help - by morzh - 03-21-2013, 05:12 PM
RE: 38-4 restoration need advice/ help - by morzh - 03-21-2013, 08:31 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
