37-690 band 2 troubles
The guy that did the rebuild claims he has attempted to rewind band 2 oscillator coils without success. I hope he is wrong and a rewind and or finding a good used one is possible. I would research what radio's use the same oscillator coils myself as my father has a complete set of rider manuals. Trouble is he is such a pack rat I would need dynamite to get to them.
37-690 band 2 troubles - by wonderwrench - 10-14-2007, 11:59 PM
[No subject] - by Sean - 10-15-2007, 09:12 AM
[No subject] - by wonderwrench - 10-15-2007, 01:36 PM
[No subject] - by Carl Travis - 10-15-2007, 03:50 PM
[No subject] - by Ron Ramirez - 10-15-2007, 05:51 PM
Coil rewinding for lower bands - by AI2V - 10-15-2007, 07:06 PM
[No subject] - by wonderwrench - 10-15-2007, 07:35 PM
There are currently 6990 online users. [Complete List]
» 1 Member(s) | 6989 Guest(s)
