Philco model 18 (code 121) - HELP!
Threads: 562
Pith
yes 450V rating is enouhg for all those caps.
As for the test, you just touch the grid cap with a wire (I touch it with my finger but if you are not at the point where you are copmfy doing that, just use a wire or a scredriver, or a meter's lead). Just touch them - you will hear a 60Hz buizz. If your audio works.
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-13-2013, 08:40 PM
Users browsing this thread: 13 Guest(s)
Philco 91 Tuning Condenser
I thought you meant the actual dial....there are rivets.morzh — 08:42 PM |
This is what I meant.morzh — 08:37 PM |
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
