Stuck Knob on 610B
Hi Perry
I moved this thread to Philco Cabinet Restoration as it seemed to be a more appropriate home for it.
Over the years, the most common "cure" I have read about for this problem is to put a piece of heavy string behind the stuck knob, wrap once around the shaft if at all possible, and then pull as hard as you can with both hands - one on either side of the knob, pulling on both ends of the string. Be aware that the knob may very well end up flying across the room.
Stuck Knob on 610B - by Perry - 02-14-2013, 03:14 PM
RE: Stuck Knob on 610B - by Ron Ramirez - 02-14-2013, 05:08 PM
RE: Stuck Knob on 610B - by Arran - 02-15-2013, 12:45 AM
RE: Stuck Knob on 610B - by Perry - 02-17-2013, 05:33 PM
New member
Philco 630csx power cord
New member
There are currently 2597 online users. [Complete List]
» 3 Member(s) | 2594 Guest(s)
