38-116 alignment hints needed
I bookmarked this one. Thanks to both of you. I'm still working on a 38-116 and could probably use some better alignment, very clear as to the approach. I have another post on my problems although the radio works well but I may have the mag tuning alignment figured out with the various problems I have had. A bad switch for the muting, a bad switch for the muting for the mag tuning using the speed dial. Then perhaps ( it appears) a miss wiring on the can of 3 caps that that kept the whole thing shut down. I must say the radio works really well.
Jerry
38-116 alignment hints needed - by FStephenMasek - 02-13-2013, 01:33 AM
RE: 38-116 alignment hints needed - by jerryhawthorne - 02-14-2013, 11:22 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
