38-4 restoration need advice/ help
See if the voltage chart mentions anything about Ohms per volt with their readings. The resistors are worth checking even without taking voltage readings into account, especially on any resistor with a body end dot code.
38-4 restoration need advice/ help - by conroyp - 02-12-2013, 10:00 PM
RE: 38-4 restoration need advice/ help - by Arran - 02-15-2013, 01:28 AM
RE: 38-4 restoration need advice/ help - by morzh - 02-15-2013, 07:26 PM
RE: 38-4 restoration need advice/ help - by morzh - 03-21-2013, 05:12 PM
RE: 38-4 restoration need advice/ help - by morzh - 03-21-2013, 08:31 PM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 8524 online users. [Complete List]
» 1 Member(s) | 8523 Guest(s)
