41-280 Bandswitch cabling
Oldradiofixerupperguy.com has the Sams dial string diagrams online.
Below is a link to a pdf file. See diagram no. 353 for the Philco 41-280.
http://www.theoldradiofixerupperguy.com/...00_355.pdf
Richard
41-280 Bandswitch cabling - by Guest - 10-17-2007, 09:59 PM
[No subject] - by rghines1 - 10-18-2007, 04:30 PM
41-280 Bandswitch cabling - by Guest - 10-18-2007, 11:13 PM
[No subject] - by Raleigh - 10-20-2007, 12:42 PM
41-280 bandswitch cabling - by Guest - 10-22-2007, 07:52 PM
[No subject] - by Raleigh - 10-23-2007, 12:37 AM
Philco 91 Tuning Condenser
There are currently 9856 online users. [Complete List]
» 1 Member(s) | 9855 Guest(s)
