Brought a Philco 38-62 home tonight
I found this rough set on my local craigslist for $20 and decided to take a chance on it.
[Image: http://farm9.staticflickr.com/8376/84770...916a_c.jpg]
[Image: http://farm9.staticflickr.com/8095/84781...e018_c.jpg]
The photo finish on the front is in pretty good condition which is the main reason I decided to go for it. The rest of the cabinet is a bit rough though. Some trim is missing at the bottom on one side and there's a nasty split in the plywood.
[Image: http://farm9.staticflickr.com/8085/84781...d12d_c.jpg]
The dial glass is missing too, unless this model didn't have any ?
[Image: http://farm9.staticflickr.com/8239/84770...5ee7_c.jpg]
I thought is was a 37-62 at first, but the label states 38-62.
[Image: http://farm9.staticflickr.com/8525/84771...97b4_c.jpg]
It looks to be 100% original inside. Speaker just has a minor tear.
[Image: http://farm9.staticflickr.com/8385/84770...f359_c.jpg]
I don't see any replaced components.
[Image: http://farm9.staticflickr.com/8112/84770...9ed9_c.jpg]
I was happy to see all glass tubes and no hacked up base shields with metal types installed.
[Image: http://farm9.staticflickr.com/8097/84781...21be_c.jpg]
After my visual inspection and testing the power transformer with an ohmmeter, I popped out the rectifier and powered it up. All the voltages look good.
Then the bad news, both the power/volume and band-switch and frozen in place. However, the power switch is frozen in the on position. Now normally I wouldn't power a set up this old with all original caps, but the seller claimed it played great and I took the usual precautions - fused variac and 60W bulb in series. Well, what do you know, it plays very well Icon_smile Only problem is that the volume is stuck at or near 100%
Note the original dial lamp was burned out and my replacement is a bit too bright.
[Image: http://farm9.staticflickr.com/8099/84770...411a_c.jpg]
Brought a Philco 38-62 home tonight - by Bob Andersen - 02-16-2013, 02:03 AM
Philco 91 Tuning Condenser
