Brought a Philco 38-62 home tonight
I saw that radio on Craigslist as well. I am over near South Bend, IN and was thinking about sending a friend of mine who is heading to Chicago this weekend over to fetch it. Glad you picked it up first though! I have too many projects as it is.
RE: Brought a Philco 38-62 home tonight - by jontz - 02-16-2013, 10:11 AM
Philco 91 Tuning Condenser
