Crosley 515 trouble shooting
Sorry for not being clear comes from being new but I'm learning.
On the 6D6 IF the socket voltage chart says I should have 3 volts but if you turn the vol control I can go from 0-93v.
No choke it is an output transformer mounted on the speaker.
Crosley 515 trouble shooting - by Eric - 02-17-2013, 05:31 PM
RE: Crosley 515 trouble shooting - by morzh - 02-17-2013, 07:35 PM
RE: Crosley 515 trouble shooting - by Eric - 02-17-2013, 08:57 PM
RE: Crosley 515 trouble shooting - by morzh - 02-17-2013, 10:27 PM
RE: Crosley 515 trouble shooting - by Eric - 02-17-2013, 11:36 PM
RE: Crosley 515 trouble shooting - by morzh - 02-18-2013, 10:55 AM
RE: Crosley 515 trouble shooting - by Eric - 02-18-2013, 01:01 PM
RE: Crosley 515 trouble shooting - by morzh - 02-18-2013, 09:06 PM
RE: Crosley 515 trouble shooting - by Eric - 02-18-2013, 09:43 PM
RE: Crosley 515 trouble shooting - by morzh - 02-19-2013, 05:30 PM
RE: Crosley 515 trouble shooting - by Eric - 02-20-2013, 06:21 PM
RE: Crosley 515 trouble shooting - by morzh - 02-20-2013, 07:12 PM
RE: Crosley 515 trouble shooting - by Eric - 02-20-2013, 09:14 PM
RE: Crosley 515 trouble shooting - by morzh - 02-20-2013, 09:41 PM
RE: Crosley 515 trouble shooting - by Eric - 02-21-2013, 09:00 AM
RE: Crosley 515 trouble shooting - by Eric - 02-21-2013, 10:33 AM
RE: Crosley 515 trouble shooting - by morzh - 02-21-2013, 05:28 PM
RE: Crosley 515 trouble shooting - by Eric - 02-22-2013, 10:25 AM
RE: Crosley 515 trouble shooting - by morzh - 02-22-2013, 11:03 AM
RE: Crosley 515 trouble shooting - by Eric - 02-22-2013, 05:03 PM
RE: Crosley 515 trouble shooting - by morzh - 02-22-2013, 05:40 PM
RE: Crosley 515 trouble shooting - by Eric - 02-22-2013, 07:36 PM
RE: Crosley 515 trouble shooting - by Eric - 02-22-2013, 09:17 PM
RE: Crosley 515 trouble shooting - by morzh - 02-22-2013, 09:41 PM
RE: Crosley 515 trouble shooting - by 7estatdef - 02-23-2013, 06:48 PM
RE: Crosley 515 trouble shooting - by morzh - 02-23-2013, 07:30 PM
RE: Crosley 515 trouble shooting - by lumberman22 - 03-30-2014, 01:38 PM
