Crosley 515 trouble shooting
It pays to tell which voltage, it lists two, though they are connected together (sujppressor and cathode). Try to be exact, name the electrodes.
Now the voltage will change. I do not have the values, but the B+ voltage gets divided between the series 21Z-21-Y and the portion of 31Z volume regulator to the GND.
If you have values, calculate how much the change is.
Crosley 515 trouble shooting - by Eric - 02-17-2013, 05:31 PM
RE: Crosley 515 trouble shooting - by morzh - 02-17-2013, 07:35 PM
RE: Crosley 515 trouble shooting - by Eric - 02-17-2013, 08:57 PM
RE: Crosley 515 trouble shooting - by morzh - 02-17-2013, 10:27 PM
RE: Crosley 515 trouble shooting - by Eric - 02-17-2013, 11:36 PM
RE: Crosley 515 trouble shooting - by morzh - 02-18-2013, 10:55 AM
RE: Crosley 515 trouble shooting - by Eric - 02-18-2013, 01:01 PM
RE: Crosley 515 trouble shooting - by morzh - 02-18-2013, 09:06 PM
RE: Crosley 515 trouble shooting - by Eric - 02-18-2013, 09:43 PM
RE: Crosley 515 trouble shooting - by morzh - 02-19-2013, 05:30 PM
RE: Crosley 515 trouble shooting - by Eric - 02-20-2013, 06:21 PM
RE: Crosley 515 trouble shooting - by morzh - 02-20-2013, 07:12 PM
RE: Crosley 515 trouble shooting - by Eric - 02-20-2013, 09:14 PM
RE: Crosley 515 trouble shooting - by morzh - 02-20-2013, 09:41 PM
RE: Crosley 515 trouble shooting - by Eric - 02-21-2013, 09:00 AM
RE: Crosley 515 trouble shooting - by Eric - 02-21-2013, 10:33 AM
RE: Crosley 515 trouble shooting - by morzh - 02-21-2013, 05:28 PM
RE: Crosley 515 trouble shooting - by Eric - 02-22-2013, 10:25 AM
RE: Crosley 515 trouble shooting - by morzh - 02-22-2013, 11:03 AM
RE: Crosley 515 trouble shooting - by Eric - 02-22-2013, 05:03 PM
RE: Crosley 515 trouble shooting - by morzh - 02-22-2013, 05:40 PM
RE: Crosley 515 trouble shooting - by Eric - 02-22-2013, 07:36 PM
RE: Crosley 515 trouble shooting - by Eric - 02-22-2013, 09:17 PM
RE: Crosley 515 trouble shooting - by morzh - 02-22-2013, 09:41 PM
RE: Crosley 515 trouble shooting - by 7estatdef - 02-23-2013, 06:48 PM
RE: Crosley 515 trouble shooting - by morzh - 02-23-2013, 07:30 PM
RE: Crosley 515 trouble shooting - by lumberman22 - 03-30-2014, 01:38 PM
