Need some ideas
Is there any way that the front panel can be removed? Is it held in with screws on the top/sides? If so...and if you are very careful, you could remove the panel and then do what you have to do to the rest of the cabinet.
A very light sanding, being careful not to go through the photofinish but just enough to remove the runs, could rescue the front panel. I would defer to the experts (Steve Davis, Gary Rabbitt, others?) on that process.
Need some ideas - by 7estatdef - 02-18-2013, 02:46 PM
RE: Need some ideas - by jerryhawthorne - 02-18-2013, 03:40 PM
RE: Need some ideas - by Ron Ramirez - 02-18-2013, 08:23 PM
RE: Need some ideas - by Arran - 02-18-2013, 08:35 PM
RE: Need some ideas - by 7estatdef - 02-18-2013, 11:22 PM
RE: Need some ideas - by Arran - 02-19-2013, 01:17 AM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2501 online users. [Complete List]
» 5 Member(s) | 2496 Guest(s)
AvatarAvatarAvatarAvatar
