  • 1 Vote(s) - 5 Average
Thoughts on a McMurdo Silver Masterpiece VI Speaker
When you are dealing with issues that require a significant an investment I would defer to the owner of the sets judgement. Many collectors strive for authenticity but unless you have won the LOTTO there are always limits. A humble collector who would like to listen to his/her set cannot be faulted because he/she has to eat and pay rent.
So as long as one is being true to his/her philosophy their work should be respected. In my humble opinion there are a lot of bad feelings created sometimes because a collectors' wish to judge others too harshly, the hobby should be enjoyable, a guy/gal should not be made to feel inadequate because someone else chooses to tell them they did not do it "right".
Now I have to go paint a model 90 florescent pink.
RE: Thoughts on a McMurdo Silver Masterpiece VI Speaker - by Paul Philco322 - 02-20-2013, 09:32 PM
Users browsing this thread: 15 Guest(s)
There are currently 10341 online users. [Complete List]
» 3 Member(s) | 10338 Guest(s)
