1934 Phico model 18(code 121) shadowmeter
I restored this radio awhile ago and it worked great. Then stored it awhile and the shadowmeter wasn't working properly. Seems the horseshoe magnet is weak. I tried to remagnatize using the method from "The Philco Repair Bench" and it actually got weaker. Has anyone tried this method or maybe some other method? I'm open to any other ideas.
1934 Phico model 18(code 121) shadowmeter - by radioman - 02-20-2013, 09:41 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
