Philco 70 tuner slips
After thinking about it, I just may leave it alone. Although Steve had a good idea with his fix. It's not like I'm going to use this radio everyday. I have the capability of reaming it straight but would still have to drill out the steel rivets holding the whole assembly, dis-assemble the spring loaded part to be able to remove the shaft to do the reaming. Maybe, we'll see. I have a few other radios I'm itching to get at like an RCA 128 I've had for two years and it's staring at me asking, "am I next".
Philco 70 tuner slips - by Ralph L - 02-19-2013, 04:09 PM
RE: Philco 70 tuner slips - by codefox1 - 02-19-2013, 06:01 PM
RE: Philco 70 tuner slips - by Ralph L - 02-20-2013, 11:23 AM
RE: Philco 70 tuner slips - by Steve Davis - 02-20-2013, 03:54 PM
RE: Philco 70 tuner slips - by Ralph L - 02-20-2013, 07:37 PM
RE: Philco 70 tuner slips - by Arran - 02-20-2013, 11:41 PM
RE: Philco 70 tuner slips - by Ralph L - 02-21-2013, 11:56 AM
RE: Philco 70 tuner slips - by codefox1 - 02-21-2013, 12:21 PM
RE: Philco 70 tuner slips - by Ralph L - 02-21-2013, 08:30 PM
RE: Philco 70 tuner slips - by Ralph L - 02-24-2013, 03:35 PM
RE: Philco 70 tuner slips - by Ralph L - 02-24-2013, 03:49 PM
Philco 91 Tuning Condenser
