Does your 38-690 have the original back?
Mine has the back but it is in several (many) pieces. It is extreamly brittle and falls apart every time I handle it. It was missing some areas when I bought it. There is a neat logo and some other writing near the lower center. I'll see if I can piece it together and take some measurements. Here's a photo when first bought. Hopefully someone has a more complete example.
Philco 91 Tuning Condenser
There are currently 4597 online users. [Complete List]
» 1 Member(s) | 4596 Guest(s)
