  • 1 Vote(s) - 1 Average
Growing up quick...with a 38-690xx Pics added.
#33
Did more testing on the power/amp chassis and found the choke #167 is open. The other choke #175 is fine. I have chokes in my junk box but nothing like this. I would prefer a direct replacement as original appearance is high on my list for this radio. Opinions? Thoughts? Thanks guys!
RE: Growing up quick...with a 38-690xx Pics added. - by badwaxcaps - 02-23-2013, 03:32 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6640 online users. [Complete List]
» 1 Member(s) | 6639 Guest(s)
